So basically I have a lotta probs to be solved
ill just tell what happened
2020: I had a pc with intel i3 8th gen, 8gb ram, 1tb 7400rpm drive, GT710 2gb ddr3
 this pc worked like charm
I played few games and stuff
2021: I got a laptop with intel i5 11th gen, 1tb 5400rpm drive,8gb ram,Iris xe graphics
 this had better performance on paper
like intel told i can play almost everygame on low settings
I tried valorant......
my hopes went skrrr
it was literally stuttering so much while the gt 710 ran smoothly
2022: my gt710 isnt working
when i connect it it shows black screen without booting
so i removed the gpu from the desktop and ran valorant
it was fine in lobby when i entered a match
It was just like my laptop, lagging, stuttering and stuff
idk what to do
Problems:
1-Why isnt my gpu working?
2-Why is my laptop and desktop(after dead gpu) now able to run valorant
3-Intel told Iris Xe can play entry level games really well while i cant evn play valorant
4-Is it the ram or the hdd?
https://linustechtips.com/topic/1416246-please-help/
