ples help
Go to solution Solved by An0maly_76,
53 minutes ago, MrBee420 said:
Where's the gpu if you are asking if this pc build is good or not?
GPU is kinda irrelevant here, as the 5600G has integrated graphics. But maybe they're not sure how well this build will suit their use? And it all depends on what the intended use is. 5600 / 5800 is okay, my new build has a 5900X, but integrated graphics are only suited for everyday use and modest gaming needs. OP, if you're planning on serious gaming with this thing, you're better off with a non-G processor and at least an RTX2060 / RTX2080ti equivalent or better, especially if you want to do 4K. Nothing less than an RTX3060ti or equivalent will do all that well with 4K.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1415928-ples-help/#findComment-15289528
