More networking questions
Solved by Allan B,
Because he is off by a few numbers.
192.168.99.0/25 would be 192.168.99.1-126 with broadcast being 127.
192.168.99.128/25 would be 192.168.99.129-254 with broadcast being 255.
Into 4 subnets you would use /26 with the 4 networks below. The network "ID" (0/64/128/192) ip you cannot use, also the broadcast IPs (63/127/191/255)
192.168.99.0/26 - 192.168.99.1-62 (Broadcast 63)
192.168.99.64/26 - 192.168.99.65-126 (127)
192.168.99.128/26 - 192.168.99.129-190 (191)
192.168.99.192/26 - 192.168.99.193-254 (255)
"/26" means the subnet mask is 255.255.255.192.
The "gateway" is whatever ip you set the firewall\router to be within each range.. (it does not have to be .1 for example)
