Do thermal pads have to have some sort of adhesive for VRAM?
mickel4190
So basically, I recently purchased a used PC with an rtx 2080. It's doing well, except the VRAM does get pretty toasty under heavier loads at 100+ degrees. And with that, I plan on changing the thermal pads which brings me to this question.
Is some sort of adhesive necessary for thermal pad? And does it have to be on both sides?
I know the question is a bit silly, since it should be obvious, but I'm not too sure about it so that's why I'm asking it here
They're sorta adhesive on their own, they stick to the VRAM chips/heatsinks fine. Shouldn't need any additional adhesive.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
