Hi guys,
I moved into an appartment with my girlfriend last year and we've got a stable 300 MBit/s internet connection in the basement.
In the basement, the fiber optic connection is transformed into an ethernet connection by a box of our ISP.
I took our router, a laptop and 2x CAT 7 network cables into the basement to check this.
In the basement there is a network wall socket and there is a network wall socket in the appartment (1st floor).
A CAT 6 cable connects these two wall sockets.
In the appartment we get an unstable 50 Mbit/s to 150 Mbit/s internet connection with the same router, the same laptop and the same CAT 7 cable from the router to the laptop.
So the problem has to be the CAT 6 cable from basement to appartment.
It's weird, because the connection is not gone completely, but it's very unstable.
So to get a stable 300 Mbit connection, we took a long (25 m) CAT 7 cable through the stairwell from the ISP box to the router and it works perfectly fine.
But this is not the way, the house owner likes it. So he sent an electronics technician. We call him cable clutter joe.
Cable clutter joe measured, if all 8 pins are connected from basement to appartment and he says, they are.
We showed him, we dont get all the bandwidth and his "solution" is this:
A square box with a round cover, a usual network cable without sockets and a socket to socket adapter. LOL.
Being an electrical engineer, I couldn't stop laughing for a day.
It looks ugly, but it works.
Unfortunately, I dont have much experience with networking, so...
What do you guys think?
Can sockets be a problem for a high bandwidth?
Was the cable broken somehow?
CAT 6 should support 300 MBit/s, right?
His boss will send him over today to fix this mess.
Strictly speaking, it's cable clutter joe's job, but after seeing his solution, I would like to help the poor guy.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1414988-network-cable-bandwidth-problem/
Non-standard cable pinout or improper connection. I've seen that a lot, electricians connecting the sockets so badly, een leaving some wires not connected because 100Mbps is just fine...
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
It supports 1 Gb/s for under 100m runs, same as CAT5e.
Generally speaking, don't add extra jack points on an individual run unless you need to. That being said no, they shouldn't be a problem.
Also you shouldn't run ethernet cables next to your power cables.
It happens (cable breaking), but what happens more often is poor crimping / bad connectors.
49 minutes ago, 191x7 said:
improper connection
Okay, so even if all the pins are connected, they were probably a little loose, which could have caused the issue.
I will keep an eye on the socket to make sure, the socket is occupied correctly and nothing is loose.
Thanks guys!
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
Thanks guys!
Just to mention, it's not a case of "the color order is the same on both sides", there are standards for the color order. Most electricians do not know that, they connect them like they were regular power cables.
A simple network cable tester can help with diagnosing such issues.
Ah, there is TIA-568A and TIA-568B, so A or B. There should be the same standard for both sockets, right?
If one socket is connected in way A and the other socket is connected in way B, could this lead to an unstable connection with less bandwidth?
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
If the different sides were connected with different standards it wouldn't work or it would have severe issues.
Okay. The difference between TIA-568A and TIA-568B seems to be a swap of the orange and the green twisted pair.
So when mixing standards, half the twisted pairs are connected correctly and I would expect half the bandwidth.
That could be the problem too.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
As an electrical engineer you're more than qualified to get some cheap network RJ45 cable crimping tools, a cheap cable tester and some cables, connectors etc and do some cabling just for fun.
You can get all that for less than 20$, if you'd want higher quality maybe 50$. You already know a lot more than the electrician.
Doing it this way results in a crossover cable, which is not what is needed here. Simply stick to one standard at both ends. The 'B' standard is now most frequently used.
I would just replace that cable with a new Cat6/6A ethernet cable with proper terminations at both ends. It's probably in need of an upgrade anyway, which will save on future problems.
Pull the new cable through using the old cable as a guide wire.
Since I'm paying rent, it's the house owners job to buy the cable and before I am not sure, if the cable is broken, I dont want to touch anything, so no one can say I destroyed the cable.
I will see how the electrician does today and if it doesn't work as expected, I will do it myself, because I'm just annoyed by this.
In the US, B seems to be popular. In europe, A seems to be polular.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
@191x7
@Biohazard777
@Falcon1986
Guys, you will not believe this.
Cable clutter joe was here and all he did was replacing the round cover for a square one.
My girlfriend goes GRRR 😄
I asked him, why he doesn't use a wall socket and he said: "I tried but it didn't work.".
I guess, I will do it myself.
iv widget
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
33 minutes ago, suedseefrucht said:
Unfortunately, I believe it... I've had my fair share of shoddy plumbing, flooring, wall painting, etc. in the last 5 or so years. It is freaking hard finding people to do at least a decent job, even when paying a fair price (and above) for said work.
And no I am not nitpicking, a floor tile shouldn't be sticking out so much that there is a chance of tripping on it.
Yep.
Don't get me wrong, I value time, but if I am gonna waste time supervising or worse fixing screw ups or finding different people for the same job... fk it I'll just do it myself.
Speaking of which, instead of mounting an RJ45 wall socket there you may want to consider putting a cheap unmanaged 1 Gb/s switch, gives you additional ports for like 15-20$
