NZXT Kraken M22 120mm weird sound
Coltonw023456
so i got this new cooler now i know i could have gotten better cooler if i wanted but i liked the color etc and the screen with the led inside and i have NZXT case as well just wanted to match how ever there is a sound coming from it i thought it was coil whine from gpu but its not cause when i unplug the pump the sound goes away but get this if im in bios it wont make the sound at all only when booting in to windows and using windows i even put the pump to full speed in bios and the only thing i heard was normal full speed pump sound so not really sure i talked to NZXT they are unsure what it is besides it is the pump but they said if i can stand the sound and its working good keep it i have a 3 year warrenty anyways i played games and stressed testing and the sound didn't get worse so
PS sorry for my spelling lol i type fast
i thought it was gpu coil whine but its not
Amazon.com: NZXT Kraken M22 120mm - RL-KRM22-01 - AIO RGB CPU Liquid Cooler - CAM-Powered - Infinity Mirror Design - Reinforced Extended Tubing - Aer P120mm PWM Radiator Fan (Included) Black : Electronics
update so i did this stress test and the sound goes away when underload but as soon as you stop the test it comes back so i guess it don't like idle lol ? maybe small air bubbles ? 734308_Screenshot(6).thumb.png.b85cab5ae95d870f64c72b1573e834a2.png
 i should have taken one after testing but i didn't
this is a type of cooler that belongs in this
i suggest to change it out
oh ikr lol i like how you put the trash can but oh yeah i know
