4K 120hz Problem
Solved by igormp,
Are you using the 2080 from your signature? If so, the 2000 lineup doesn't support HDMI 2.1, so the max you can do is 4k60hz, try to see if this works.
Vibora ·
Posted in New Builds and Planning3 -
3
3
Doctah ·
Posted in Peripherals1 -
5
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards3 -
Packhunter ·
Posted in Graphics Cards5 -
12
