Budget (including currency): $1000 USD (Somewhere around that, I can pitch in more if it's less than $200 more).
Country: US
Games, programs or workloads that it will be used for: Gaming; VR Games like Blade and Sorcery, Gorilla Tag, Rec Room, Pavlov, etc. Minecraft, Valorant, Cs:go, Discord, CarX, Rocket League, Various Bluestacks games.
Other details I'm not waiting for prices to drop, Unless advised to strongly. I will buy it soon since I am impatient and my Birthday just passed.
Hey, I'm building a new PC and it's my first time doing it. I have a decent idea on what specs I want (I think), And I was wondering if anyone could help me. Maybe tell me if I can replace parts to make it better, have a lot replaced, or if I can make a better one with my budget. Thanks 🙂
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive
Monitor is already bought, may buy another one in the future but it is not relevant right now.
This is the one that I could make, (Looking for a white theme)
https://linustechtips.com/topic/1413313-pc-help/
What resolution/refresh rate is the monitor you bought? Looks pretty good to me overall, other than the power supply. Do you need an SFX (smaller form factor) model for any particular reason? I see you're going with an ATX case, so an ATX power supply would be fine (not to mention quite a bit cheaper). The Corsair RMx 750W is a good option if you're looking to have some headroom for upgrades down the line, or you could step down to the 650W model to save a buck (Nvidia recommends 650W for the 3060ti, and it should be fine with the 5600X, assuming it's a decent quality unit).
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1413313-pc-help/#findComment-15272089
Hi! My monitor is https://www.amazon.com/gp/product/B01JGYM5H6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 (This is the ASUS VG245H) And it's refresh rate is 75hz with 1080p. Also, i've switched from the old power supply to your Corsair RMx 650W White version.
Question: Is the Rtx 3060ti Supposed to be $300, or over $600? I'm a little confused on which one i'm buying lol.
Also, Sadly it's way more money than I thought due to my RTX 3060ti confusion. Is there anything that I can substitute out for it to be cheaper and not effect the quality too much?
Also thank you so much for your help 🙂
https://linustechtips.com/topic/1413313-pc-help/#findComment-15272331
