Need Help with New PC
Unless what you're doing really likes AMD CPUs, you're better off going Alder Lake. The 12400 is marginally faster in most workloads and costs $100 less.
https://pcpartpicker.com/list/rwBNGL
Went Alder lake. I'm guessing you're going for an all white build so I tried to match that with the other components (given it doesn't cost a crazy amount extra).
Replaced the cooler for one LGA 1700 compatible, though I would personally ditch it and just run the Intel Stock cooler, it's plenty for a 12400.
Swapped the RAM, 3600CL18 RGB is $1 more and a bit faster, though if you don't care about RGB Crucial Ballistix memory would be a better call.
Added a 2TB HDD because 500GB goes really fast.
Swapped the fans for a 5 pack because it's actually cheaper than getting 3 separately. With the $5, get a USB to fan adapter and just point them at yourself, or use them as spares in case one dies.
