PALIT GEFORCE RTX 3080TI GAMING PRO LOUD FAN PROBLEMS
Solved by RMTM,
21 minutes ago, Rippers45 said:Finally i found a fix after so i actually just tinkered around with the temp limit and power limit, i reduced the power limit of the fan and reduced the temp limit and that did it no more engine like sounds the fan is now quiet i tried doom eternal maxed out at the temp is staying around 65-70c, the only question i have is if i reduce the temp limit to 74c and the power limit to 61c can that damage my card
No. It will not damage your card. If ever you have adjusted anything outside the cards capabilities. It will just freeze and/or restart. Then you'll just have to reset your cards settings and do some adjustments again. Until you find your stable settings.
