upgrade advice I need some advice.
Solved by Somerandomtechyboi,
What will you use it for? If its just gaming or tasks that require single thread i suggest getting an unlocked xeon like the e5 1650 v2 or 1680 v2, youll also wanna mess around with overclock and bclk overclock as old platforms are mandatory to oc otherwise youll get garbage performance, for bclk oc have a look at those x79/99 bclk oc threads
