Budget (including currency): 200 to 250 usd
Country: United States
Games, programs or workloads that it will be used for: General online gaming, some fortnite, GTA5, though the last two are not needed to keep price low
Don't need any peripherals, current list is listed below:
https://pcpartpicker.com/list/9m73C6
PCPartPicker Part List: https://pcpartpicker.com/list/9m73C6
CPU: AMD Athlon II X4 620 2.6 GHz Quad-Core OEM/Tray Processor  ($59.49 @ Amazon)
CPU Cooler: ARCTIC Alpine AM4 CPU Cooler  ($11.99 @ Amazon)
Thermal Compound: Arctic Silver Ceramique 2 Tri-Linear 2.7 g Thermal Paste  ($4.90 @ ModMyMods)
Motherboard: Asus M5A78L-M LE/USB3 Micro ATX AM3+ Motherboard  ($89.44 @ Amazon)
Memory: G.Skill Ares Series 4 GB (1 x 4 GB) DDR3-1600 CL9 Memory
Storage: PNY CS900 120 GB 2.5" Solid State Drive  ($20.99 @ Amazon)
Video Card: VisionTek Radeon HD 5450 2 GB Video Card  ($64.98 @ Amazon)
Case: Cougar MG120 G MicroATX Mini Tower Case  ($44.90 @ Amazon)
Power Supply: LC-Power LC6 V2.3 450 W 80+ Bronze Certified ATX Power Supply
Wireless Network Adapter: Rosewill RNX-N150NUB USB 2.0 802.11a/b/g/n Wi-Fi Adapter  ($5.99 @ Newegg)
Monitor: Dell E1913S 19.0" 1280x1024 60 Hz Monitor
Total: $302.68
Generated by PCPartPicker 2022-02-13 01:13 EST-0500
Looking for ways to reduce the price. I have a LC power 420w PSU, and 1gbx4 DDR3 g skill ram, 2gbx2 DDR3 g skill ram on hand right now, as well as a Dell monitor VGA from about 20 years ago that I would like to use as well. Any advice is greatly appreciated.
Peakbagger41
https://linustechtips.com/topic/1411456-budget-pc-build-help/
Go used, and don't buy basically any of those parts. That's an ~8 year old platform that was slow when it came out. The only reason you bought it when it was new was because it was cheap, but buying it new now is basically buying e-waste.
$200 is not a lot of money to work with, but getting a Haswell prebuilt for this price isn't too hard. Go for something with an i5 4460 or i7 4770 and just use it like it comes. Add in an SSD and use the iGPU since it's faster than that GPU you selected.
https://linustechtips.com/topic/1411456-budget-pc-build-help/#findComment-15258796
Buy a sandy bridge and newer core i7 midtower/full tower optiplex for $100
Buy a HD 7970/280X/380 or better at $100
Buy a power supply for $50
Optiplex 790 minitower: https://www.ebay.com/itm/203829419699?hash=item2f752e1eb3%3Ag%3AM4kAAOSwkXJiBtAh&LH_BIN=1
HD 7970: https://www.ebay.com/itm/384731593171?hash=item5993ca39d3%3Ag%3AmLkAAOSwHIFiCEp9&LH_BIN=1
EVGA BQ 600W 80+ Bronze Semi-Modular: https://pcpartpicker.com/product/DmWrxr/evga-bq-600w-80-bronze-certified-semi-modular-atx-power-supply-110-bq-0600-k1
Total: $250
This is a significantly better build than the one you listed.
The HD 7970 is a beast,a former flagship.
The Core i7 2600 is 4 cores 8 threads,a capable chip.
Also you can buy a R9 290X for $150 instead of the HD 7970https://www.ebay.com/itm/194815513862?hash=item2d5be8d506%3Ag%3AifkAAOSw6Idh~Gtq&LH_BIN=1
Whichwill raise the total price to $300
Edited by Vishera
Fixed some crucial mistakes i made,added some stuff
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1411456-budget-pc-build-help/#findComment-15258815
8 minutes ago, Vishera said:
Edited just now by Vishera
It's important to note those changes:
I had to change the link of the HD 7970 due to a defective item.
I added the option for a R9 290X,which is noticeably faster than the HD 7970.
https://linustechtips.com/topic/1411456-budget-pc-build-help/#findComment-15258822
