Budget: 1000 USD (not including the graphics card)
Country: USA
Games, programs or workloads that it will be used for: Sea of thieves, Minecraft, Halo, Payday 2, and R6
Other details: I already have an RTX 3060. My preference is an Intel i7, 144 fps, be able to have 2 monitors, Here is an pc part picker for what I think looks good.
https://pcpartpicker.com/list/Y3wQ78
This is my first build, so please let me know anything that could make it better.
https://linustechtips.com/topic/1411378-first-pc-build/
Country: USA
Don't buy windows and use the money to get a newer gen cpu
Big nerd.
 PCPartPicker List Link
Ryzen 5 1400, Deepcool Gammaxx 400 V2 Blue, Biostar B450MH, Timetec 2x8GB 3200MHz CL16, Adata SU650 240GB, WD Blue 250GB 7200RPM, Seagate Barracuda 320GB 7200RPM, MSI Aero GTX 1060 3GB, Cougar MG130G, Segotep 750W Fully Modular 80+ Gold, HP 22EB, Samsung S22E450D, Sceptre E205-W, Gamakay LK67 with Gat Reds and HK Gaming Chalk keycaps, Logitech G305 Lightspeed, Shure MV7, Gertisan Mic Arm, OneOdio Headphones, CM SickleFlow Blue Fan, Iceberg Thermal IceGALE 140MM Teal x2, Cougar case fan
Rack Project (Build log link)
https://linustechtips.com/topic/1411378-first-pc-build/#findComment-15258229
There are a lot of things you probably should change to make this build better.
1.) Go for 12th gen Intel. The i5 12400 will outperform the 10700k, even in multi threaded applications. Unless you're getting it for dirt cheap, it really doesn't make any sense to go for a last gen platform.
2.) If you're going 12400, ditch the Hyper 212 and just run the stock cooler. If you're gonna go for a 12600k or something higher, then swap the cooler out for something better. The Scythe Fuma 2 is $10 more and much better, the Arctic Freezer X34 Dual eSport is the same price and comes with 2 fans, and a couple other options out there as well.
3.) You can get better memory for less. Crucial Ballistix for the same speed bin is $25 less and is more or less guaranteed to have pretty solid memory chips.
4.) You can get a faster SSD for the same price.
5.) don't spend full price on the Windows key, get one for $20 from a key reseller.
https://pcpartpicker.com/list/grR3C6
Doing that saved $300 and got you better performance. You can use that for better peripherals, more games, or scalp your 3060 and buy a 3060Ti/3070 from another scalper with the extra money.
https://linustechtips.com/topic/1411378-first-pc-build/#findComment-15258240
Thanks, what is a good place to get a windows key from?
https://linustechtips.com/topic/1411378-first-pc-build/#findComment-15258249
I've seen them on eBay, there are a ton of sites that specialize in selling game keys that are pretty good to get them off of. The first one that comes to mind is Kinguin, but there are definitely others out there. Personally I just run my Windows unactivated and don't really care so don't know the proper channels to go through getting one, but I know they exist for around the $20 mark.
https://linustechtips.com/topic/1411378-first-pc-build/#findComment-15258263
