Country: USA
so im needing to get a new mobo due to broken rear usb ports i currently have a rog strix b450f and im getting a better case as my new card is a nice tight fit(ASRock OC Formula Radeon RX 6900 XT 16GB )im looking at a H710I and a N7 B550 do i need adapters for the usb c cables or are they direct fits
I just get confused by all the differnt standard lables like USB 3.1 Gen 2 type c and all that stuff
also whats a good pci riser for the verticle mount
my current build
R5 3600
cooler master hyper 212 black
16gb (8+8) ripjaws
rog strix b450f gaming
2 m.2 1tb drives
2tb segate baracuda 3.5
500gb kingstone ssd as a backup/reco drive
https://linustechtips.com/topic/1411337-front-io-plugs/
1 minute ago, RONOTHAN## said:
Don't, that case has basically no airflow and your 6900XT will likely thermal throttle.
All the front IO stuff will work just fine.
with the vertical mount or as standard mount
also i usualy run with open side panel
https://linustechtips.com/topic/1411337-front-io-plugs/#findComment-15257943
That's not a viable solution to thermals, and also retards the case design aspect.
Like if a car doesn't allow much air to the radiator, do you remove the front end?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1411337-front-io-plugs/#findComment-15257947
Both, especially vertical mount since it's pressed right against the side panel.
Also I've dealt with the H710 before (bought it in a system I was gonna part out), and the side panel is a nightmare to mount. It's just not a good case, it may look pretty but it's not well designed, and if you're gonna be running it without a side panel all the time you're better off just buying an open frame chassis instead of it.
https://linustechtips.com/topic/1411337-front-io-plugs/#findComment-15257960
Why not a known good case with proper airflow?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1411337-front-io-plugs/#findComment-15257967
