Ryzen  5 5600
msi b550 gaming plus
corsair vengeance ram 3200mhz
so i can boot up with 1 ram stick in b1 slot but when i put both sticks in b1 and b2 slots the pc throws up the dram light on the board ?
all sticks work and our from my main gaming pc as i thought the 1 of the 2 new crucial sticks i brought for this build was faulty but it seems i just carnt boot up with 2 stick in any help would be great .
bio is updated and all windows updates ect are also update now just carnt run dual channel
https://linustechtips.com/topic/1411133-dram-problem/
It's hard to say why it wouldn't boot. Modern motherboards shouldn't care too much if RAM isn't inserted in dual channel with two sticks, but in theory it is possible.
I would check the motherboard manual for which slots are ideal for only two sticks. You should also confirm on the dram sticks themselves if the manufacturing dates are the same, serial numbers near matching too. I would also verify both sticks boot on their own to isolate a faulty stick.
I've had tons of problems with Corsair DDR4, so it doesn't surprise me too much; however repeating the issue with the Crucial makes it seem like its not the Corsair's fault
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1411133-dram-problem/#findComment-15256832
hello i have done all this all sticks are from my main pc so i know they work i have evening tryed the sticks that i brought for this build in my other pc they work all sticks work in slot b2 and pc boots up soon as i add 2 sticks it just wont load up at all throws on the dram light
https://linustechtips.com/topic/1411133-dram-problem/#findComment-15256844
1 minute ago, lvlasked said:
yeah sorry im tired been at this all day either way it only boot with 1 stick in a2
So it basically will only boot with one stick in each channel?
For example, it will boot with sticks in a1 and b1 or a2 and b2; but will not boot with all 4 slots filled
*GPU Test Bench*
https://linustechtips.com/topic/1411133-dram-problem/#findComment-15256847
get a error saying memory in wrong slot in i put it in a1 or b1 but if i put ram in 1 ran stick in a2 it boots up if i put one stick in b2 it boot up but say its not optimized but if i but the sticks in A2 and B2 where there ment to be so you can run dual channel no go throws the dram light on
https://linustechtips.com/topic/1411133-dram-problem/#findComment-15256851
So are you trying to run 4 sticks of RAM?
*GPU Test Bench*
https://linustechtips.com/topic/1411133-dram-problem/#findComment-15256854
3 minutes ago, lvlasked said:
no just 2 so its in dual channel but it only works with 1 stick in
You have to be in a1 and b1 or a2 and b2 to get dual channel.
If you try running a1 and a2 or b1 and b2 it will be single channel and explain why it says memory is in wrong slot. That shouldn't prevent it from booting, however.
Edit: I see what you're saying is wrong now. Your grammar/wording has been confusing lol.
Sounds like the board might be faulty. You could try clearing the CMOS or updating the BIOS before attempting to run 2 sticks again; but its sounding like you may need to RMA the board.
*GPU Test Bench*
https://linustechtips.com/topic/1411133-dram-problem/#findComment-15256878
