I'm thinking of changing a few of my PC components. Specifically motherboard, processor, ram and GPU. (Those are Asrock H81M hds r2.0, i5 4460, 8gb ddr3, gtx 1050). I'm planning to try to sell those for what I can get and buy i5-12400f, Asrock b660m hdv, 32gb ddr4, rx 6600 XT. My case, storage and PSU seem fine, this was a prebuilt PC, but I can clearly see that PSU is 80+ bronze and 500W. Will that be enough (it has needed connectors). I also have 2 hdds, dvd drive, SATA ssd. Outer vision says I need around 430 W for these components? Is this PSU enough then? (it probably isn't quality PSU as it was prebuilt, but I never had any problems with it).
https://linustechtips.com/topic/1410470-psu-power/
Does it have a model number on the label? Probably looking at about 300-400W for the system, so a decent 500W would be fine.
Since you're selling most of the old system you might be able to get a better price if you sell it as a complete system and just buy all new parts for the new computer (maybe keeping storage drives from the old system).
https://linustechtips.com/topic/1410470-psu-power/#findComment-15252089
What are you going to do with your PC? 16GB  ram should be enough
https://linustechtips.com/topic/1410470-psu-power/#findComment-15252834
500W should be sufficient, but I would suggest getting a 650W, it would likely be quieter and degrade slower, it might not even need to turn on the fans
PSU is not the thing to cheap out on, if it fails, it could be detrimental
https://linustechtips.com/topic/1410470-psu-power/#findComment-15252860
