Welcome to VA panels.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
6 minutes ago, Tavorsk said:
I got the Acer ED320QR recently and i have ghosting i tried overdrive turned it on extreme and still does not work please help me I am desperate.
All LCD panels have ghosting to some degree (or smearing if they have the option to fully disable overdrive), the question is how obvious it is.  The higher the overdrive setting, the worse it will be.
-> Moved to Displays
F@H
GPD Win 2
1 minute ago, Tavorsk said:
what shall i do?
There's nothing you can do other than try a different monitor, if its still annoying you with overdrive on the lowest setting.
As mentioned above, VA panels tend to be worse as the overdrive has to be more aggressive to try to offset the slower pixel response time.
