Budget (including currency): £1800 GBP
Country: UK
Games, programs or workloads that it will be used for: Mainly used for gaming
Other details
Firstly i am completely new to home building a PC so any help with parts will be incredibly helpful.
Parts list:
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor
CPU cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler
Motherboard: MSI B550-A PRO ATX AM4 Motherboard
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
Storage:Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive
Video card: MSI GeForce RTX 3060 12 GB GAMING X Video Card
Case: Lian Li Lancool II Mesh ATX Mid Tower Case
Power supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Upgrading from a pre-built Lenovo (unsure on specs) about 6 years old and can tell when running it that it's on it's last legs.
Preferably buy ASAP once I'm confident that all components will happily work together with no bottle necks.
Looking for 144 Hz
I realise i may have over done it in areas but i wanted to make sure that it'll stand the test of time as games are getting bigger and bigger.
Edited by Settings3
Link to PC part picker wasn't working according to comments so typed parts instead
https://linustechtips.com/topic/1409559-first-pc-build-idea/
Bottlenecks appear though usage not simply selecting parts. What you do with the machine will dictate where a bottleneck is regardless of the machine being used
https://linustechtips.com/topic/1409559-first-pc-build-idea/#findComment-15245599
so true.. but you can still tell it'll probably shut down or crash in games unexpectedly. 🙂
https://linustechtips.com/topic/1409559-first-pc-build-idea/#findComment-15245632
Well no stability would also be dictated by usage and not simply part selection. Unless the parts were specifically not made to be compatible or were obviously very low quality then determining stability would be speculation without actually testing it.
https://linustechtips.com/topic/1409559-first-pc-build-idea/#findComment-15245656
My recommendation...
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor (£248.09 @ Technextday)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler (£68.48 @ Amazon UK)
Motherboard: Gigabyte Z690 UD DDR4 ATX LGA1700 Motherboard (£169.90 @ Infinite Computing)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3733 CL17 Memory (£66.98 @ Amazon UK)
Storage: Sabrent Rocket 1 TB M.2-2280 NVME Solid State Drive (£99.99 @ Amazon UK)
Video Card: Sapphire Radeon RX 6700 XT 12 GB PULSE Video Card (£700.79 @ Overclockers.co.uk)
Case: Fractal Design Meshify C ATX Mid Tower Case (£69.98 @ Amazon UK)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply (£79.00 @ Computer Orbit)
Monitor: BenQ EX2780Q 27.0" 2560x1440 144 Hz Monitor (£239.98 @ Amazon UK)
Total: £1743.19
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1409559-first-pc-build-idea/#findComment-15245795
