I got a i9 10900k (build year Nov, 2020 )
With 3090
Ram:- 128 gb
Motherboad :- msimsi meg z490 unify
Power:- corsair 1000 wt gold
It's been problematic for few days
After taking some windows qualitative and cumulative update it's behaving abnormally. Shows BSOD about karnel power failure... Tried to
Auto repair and start up repair but failed... At last clean reinstall windows 10 ... But after a day... PC again behaved abnormally
Fans without reason (while playing BF2042) suddenly ramming up.. PC shuting down abruptly... And auto restating rather trying restarting but failed... Again same cycle.. But now PC completely refuses to boot
Motherboard internal power switch led but no light any where except cmos button...
Tried to reset... It's starting (sometimes) and immediately stoping...
Even tried updating bios... But the bios button also behaving Eradically ... Sometomes solid red and other times blinking non stop.
Failed find any answer... Can anyone through a light
https://linustechtips.com/topic/1409460-pc-technical/#findComment-15245058
Can you get into the BIOS and keep it open without the PC shutting down on you?
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1409460-pc-technical/#findComment-15245083
