Hi as the title says the PC is overheating occasionally, the CPU shoots up to 90c+ when trying to play any title game. Just idling it sits at about 55c and when have multiple chrome tabs open for work it goes to about 65-70c, add in an Oldschool Runescape client and it wants to shoot to 80c+ occasionally will overheat there too and reach 100c. This is my first build, I am not too well versed on where to look for problems and I would appreciate any help trying to figure out what is wrong. AIO pump feels like it is working all fans are working properly in my case. AIO is also overhead mounted in case (was careful to make sure any air bubbles stayed in radiator. Assuming this could be a voltage problem, I am not sure.
Edit- Slow day of work, I am going to take off the front glass panel to see if this helps any with temps.
Build Specs
  • CPU
AMD Ryzen 9 5900X
  • CPU Cooler
Lian Li GALAHAD AIO 240 RGB 69.17 CFM Liquid
  • Motherboard
Asus ROG Strix X570-F Gaming ATX AM4
  • Memory
G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16
  • Storage
Samsung 980 Pro 1 TB M.2-2280 NVME SSD
  • Video Card
EVGA GeForce RTX 3070 8 GB XC3 BLACK GAMING
  • Case
Lian Li Lancool II Mesh ATX Mid Tower
  • Fans
   3x - CORSAIR - LL Series 120mm
  • Power Supply
Corsair RM850 W 80+ Gold Certified
  • Operating System
Microsoft Windows 10 Home OEM 64-bit
https://linustechtips.com/topic/1408614-pc-overheating/
Not seeing any obvious cause from your specs. Did the AIO come with pre-applied thermal paste or did you add your own? Also, if the cold plate had a plastic sticker on it, make sure you removed that. May seem silly, but even Linus has messed that up before.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1408614-pc-overheating/#findComment-15239228
I applied my own thermal paste. I have reapplied about 5 times now to trouble shoot it being my thermal paste. I did take the sticker off.  Is there something else I can post to help with any problem solving?
https://linustechtips.com/topic/1408614-pc-overheating/#findComment-15239245
