Hi guys, so no one is responding to my other posts so I thought I make another one as I'm really desperate. So, a few hours ago, my router just all of a sudden died. I smell no burning. This is what it says: Type: xfinity...... Power: on........... Us/ds: flashing............... Online: off........... Tel1: off.............. Tel2: off............ Battery: off. All help is appreciated!
https://linustechtips.com/topic/140855-router-problems/
Making yet another post about the same thing will not solve your problem, this thread will probably be removed as well.
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/140855-router-problems/#findComment-1880255
This topic is locked.
Please refrain from purposely making multiple topics.
Your original topic is here; if no one is responding it is likely that they are unsure of the issue.
You should contact your ISP or router provider and ask for technical assistance and/or a replacement.
https://linustechtips.com/topic/140855-router-problems/#findComment-1881310
Guest
