Hello,Recently I've been facing a problem where my laptop's CPU Clock speed instantly drops to 0.78Ghz after the CPU utilization reaches 100%. It's weird because right when the CPU's Clock speed decreases My GPU's utilization drops like 20% at the same time. I first thought it may be the Windows updates,i deleted all the windows updates,switched 3 OS,tried switching power plans but nothing seemed to work. I also forgot to mention in literally EVERY game i get fps drops because of this,even though i have the recommended system requirements.But i well remember 4 months ago i had no problem with fps drops.
Does anyone know a fix to this?
PS:My GPU's drivers are up to date,atleast that's what device manager says
Specs:
DDR3 4GB Ram
Intel Core I5-2410 CPU 2.30 Ghz (goes up to 2.69 with turbo)
GPU : GT 525M 2GB Vram
https://linustechtips.com/topic/1406660-my-cpu-clock-speed-randomly-drops/
Have you made sure the CPU is properly cooled? Usually thermal throttling doesn't drop clocks in this particular way but it's possible.
Primary PC:
PSU tier list
How many watts do I need?
8 minutes ago, YoungBlade said:
This sounds like thermal throttling. What are your thermals like? You can use a program like HWInfo64 to check.
Thank you for your fast response but yeah you're probably right because i havent changed my thermal paste since i got this laptop (which is 11 years) lol
I cant say much since it's a laptop,but i've monitored the CPU Usage and yeah i've noticed that it gets hotter way faster than 4 months ago
