Having problems with a PCIe to M.2 converter card
Solved by AbydosOne,
6 minutes ago, Indigaming6431 said:The Problem is that the converter only seems to work if my second m.2 slot on the motherboard is empty
See note 2 from motherboard spec site:
Featured Topics
INotPablo ·
Posted in Peripherals1 -
LT2 ·
Posted in Laptops and Pre-Built Systems4 -
7
joshfrog ·
Posted in Mobile Gaming5 -
5
1
f23948 ·
Posted in Programs, Apps and Websites3 -
1
1
