Hi, I'm building a new pc and my brother gifted me the Lianli OD11 Mini case. I already have a full size ATX motherboard and a rtx 2060. I was looking at 650W SFXL powersupplies and a lot of the reviews mentioned the cables were too short even for some itx cases. Does anyone know if thats an issue I need to look out for? Should I buy extra cables or are there any good suggestions for the case?
https://linustechtips.com/topic/1405384-psu-cable-length/
Could always buy cable extensions if they are too short.
I got these just for looks but if you do run into issues with length I recommend these.
https://www.amazon.com/EZDIY-Sleeved-Cable-Extension-Extra-Sleeved/dp/B074LJY8XS/ref=sr_1_21?keywords=custom%2Bcables%2Bpc&qid=1642704406&sr=8-21&th=1
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1405384-psu-cable-length/#findComment-15217844
I used a Corsair SF600 and it worked fine for me. Even had some extra length on the 24 pin I had to hide. Keep in mind that this case puts the PSU directly behind the motherboard. It's not trying to run to the front of the case and then up to the top. It's pretty much right there. 6800xt, I was able to get both PCIE 8 pins just fine as well.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1405384-psu-cable-length/#findComment-15217847
  Reveal hidden contents
Yep.  I have an SF600 in a Meshify and only needed to get a longer EPS12V.  Cost all of $5.
https://linustechtips.com/topic/1405384-psu-cable-length/#findComment-15217971
