RM750 (2019) : a few questions about burst mode
9 hours ago, Cifer said:Thanks for the info !
I therefore deduce that the burst mode on the non-x does make noise... which means I dodged a mighty bullet right there...![]()
No.聽 The RM doesn't make noise either.聽 聽It's literally the same platform.聽 I just missed where you asked about both.
聽
You run into noise with burst mode when you literally drop an IC that supports it in place of another IC that doesn't without changing anything else.聽 A lot of PSUs have done this and these are the ones that make the noise.
聽
9 hours ago, Cifer said:You could have done what miners do, but instead you went out of your way to include relays.
Could you please explain why?
Don't remember.聽 That thing was written 15 years ago.
聽
I think the signal was too weak to trigger the second PSUs.聽 But I've also just split the power good across two PSUs and have had that work too.
