I have the
HP pavillon 15.6 gaming laptop model: 15-ec2008ca
Battery: 3 cells 52,5Wh
https://www.bestbuy.ca/fr-ca/produit/portable-jeu-15-6-po-pavilion-hp-noir-ryzen-5-5600h-d-amd-ssd-512-go-ram-8-go-gtx-1650-bo/15646133
And it last me like 1hour ~ MAX 2 hours
At work doing excel, word and spotify like if i forgot my charger at home i cant do a full day on it
Bought it at first in case i wanted to game on it thats why I wanted a laptop with a GPU but i’m not gaming on it was considering to swap for a
Dell XPS15
Battery: 3 cells 56 Wh
https://www.dell.com/en-ca/shop/dell-laptops/xps-15-laptop/spd/xps-15-9510-laptop/nxps159510_ps1e
Was wondering if that battery would last longer? Since it doesnt have s 1650 in it or it will result in same performance
or even the XPS 17
6-Cell Battery, 97WHr
https://www.dell.com/en-ca/shop/dell-laptops/xps-17-laptop/spd/xps-17-9710-laptop/nxps179710_s1e
i also know that dell has a Inspiron series that are a little bit cheaper, so let me know guys :)
https://linustechtips.com/topic/1404339-laptop-battery-question/
Sounds like that Laptop has it's GTX 1650 running in Idle too.
Usually with "normal tasks" like Word, Excel, Spotify, you shouldn't be able to kill it within 2 hours.
Gaming Notebooks are usually tuned to have maximum performance. CPU is a H-series with 45w, GPU also draws alot of Power.
Any Ultrabook or Model without a dedicated GPU should last at LEAST 6-7 hours.
Dell XPS 15 9310, according to Notebookcheck, lasts for like 7 hours. But that's with a 3,5k Oled Screen. And that's with a massive 86 Wh Battery.
If you're not tied to Windows, how about a Macbook Air M1, or even the Macbook Pro M1? With only Excel, Word and Spotify, they WILL last you much more than 8-10 hours. My M1 Macbook Pro once lasted 8 hours with basic Office, and only lost 40% Battery during that time. I have no chance in killing it in a day.
Even in a Zoom conference with Cam and Mic on, it lasts for over 10 hours.
Or: If you have a Desk for working, consider a Docking Station with Power Delivery. So you connect the Notebook to a Desktop Monitor and gets charged atr the same time.
Maybe i'll try to see if i cant desactivate the GPU while i do word excel
otherwise i'll try to sneakout a ultrabook without
a gpu in it 🙂 and i'm scared to try macbook
10 hours ago, Alkor94 said:
I have the
Dell XPS15
or even the XPS 17
i also know that dell has a Inspiron series that are a little bit cheaper, so let me know guys 🙂
Try silent mode but turn it off when plugging in your laptop and gaming or else it will reduce performance. You lose a bit of fps turning on silent mode but your battery lasts longer
