Hello! I have this situation where I am using a piece of software to merge metadata from a json file to pictures and videos. Some of these files are doubled which automatically gives them a (1) at the file ending. However, Windows has done this in a weird manner so that the file names between the media files and the JSON files do not match up. They are like this. PHOTO: "Photo(1).jpg" and ""Photo1.jpg(1).json". As you can see these file names do not match up which leads to the software that I'm using to fail. Is this possible to fix in Excel without having to do it manually for thousands of file names?
https://linustechtips.com/topic/1403672-need-help-with-syncing-file-names/
