So I have been thinking about getting a gaming PC for a bit so started specing one out but only know a little about the specs. I need help this what I got so far can you let me know if it looks ok.
https://uk.pcpartpicker.com/user/TheActualAdam/saved/#view=8WZLcf
1. Budget & Location
Preferable below £1000 but i can push for £1500.
UK.
2. Aim
Main aim is to play GTA fiveM and maybe stream a little. But wanna be able to play newer games too on low settings if needed.
Needs to be a small ish case as i dont have much room. But at the same time this is my first build so preferably a case that is easy to build in.
Also i haven't added a gpu cause of the low stock but at the same time might wait till 3050 is out. So integrated graphics for now.
3. Monitors
I have one 4k 60 29inch but thinking about adding another.
Will be gaming at 1080p.
4. Peripherals
I have a mouse and keyboard in mind so good for that.
I will need windows included in price.
5. Why are you upgrading?
My laptop is getting old and slow. I currently play games on my xbox but want to get a PC so I can play different games and still do the stuff  I use my laptop for.
https://linustechtips.com/topic/1403268-mini-itx-build/
Consider a latest generation cpu.
The mATX case is a little larger than the H210 so it offers a slightly roomier interior. Making for easier assembly and better cooling.
PCPartPicker Part List
CPU: Intel Core i7-12700 2.1 GHz 12-Core Processor  (£354.00 @ Infinite Computing)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  (£69.27 @ Amazon UK)
Motherboard: MSI MAG B660M MORTAR WIFI DDR4 Micro ATX LGA1700 Motherboard  (£199.98 @ CCL Computers)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£61.99 @ Box Limited)
Storage: Western Digital WD_BLACK SN750 1 TB M.2-2280 NVME Solid State Drive  (£95.99 @ Amazon UK)
Case: Fractal Design Meshify C Mini MicroATX Mini Tower Case  (£79.98 @ Amazon UK)
Power Supply: SeaSonic FOCUS GX 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£84.33 @ Box Limited)
Total: £945.54
Generated by PCPartPicker 2022-01-12 15:40 GMT+0000
https://linustechtips.com/topic/1403268-mini-itx-build/#findComment-15202678
UK.
2. Aim
3. Monitors
4. Peripherals
12400F+RX 6600, will cost you an extra $100 on top of the other one, but it should perform better in most modern games
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  (£178.75 @ Infinite Computing)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard  (£143.47 @ Ebuyer)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£53.71 @ CCL Computers)
Storage: Western Digital Blue SN550 1 TB M.2-2280 NVME Solid State Drive  (£67.90 @ Amazon UK)
Video Card: Gigabyte Radeon RX 6600 8 GB EAGLE Video Card  (£426.00 @ Amazon UK)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  (£44.97 @ Amazon UK)
Power Supply: be quiet! Pure Power 11 FM 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (£79.31 @ NeoComputers)
Operating System: Microsoft Windows 10 Home Full 32/64-bit  (£109.85 @ More Computers)
Total: £1103.96
Generated by PCPartPicker 2022-01-12 16:00 GMT+0000
https://linustechtips.com/topic/1403268-mini-itx-build/#findComment-15202713
