Micro B to USB3 Cables Difference
Go to solution Solved by Kaaverik,
I do not think there would be much of a difference aside from a small bump in slower and faster transfer speeds between brands. Since USB 3 is a standard the cables have to be built to handle the throughput of the data required by the standard. Every manufacturer can change the cable appearance in any way they want, but at the end of the day it just has to meet USB transfer speeds 🙂
Also, all hard drives will operate at a somewhat reduced speed due to seeking, reading and writing times, which for a sata disk just happens to be 600Mb/s, the same transfer speed as USB 3.
Please quote me in your messages so that I am notified!
Remember to mark my post as answer if it answered your question!
Thank you! 😄
CPU: Ryzen 5 2600 @4.5ghz| Motherboard: Gigabyte AORUS M Micro-atx |
RAM: 16gb Corsair Vengeance @ 3200mhz | GPU: Powercolor Red Devil Vega 56 |
Case: Cooler Master NR400 | Storage: 512gb ADATA SX8200 Pro, some 2tb hard drives |
PSU: Seasonic Focus+ 750w Platinum | Display(s):Viewsonic XG2402 / AOC I2367FH |
Cooling: Scythe Kabuto 3 / 3x Thermaltake Riing RGB Fans | Keyboard: Corsair K65 Lux |
Mouse: Corsair Harpoon | Sound: Steelseries Arctis 3 | Operating System: Windows 10 Home
24 minutes ago, tkitch said:
Micro B is a USB 1 or 2 standard, you don't need a USB 3 microB cable.
There are actually Micro B 3 cables. They're called micro B super speed, a micro B superspeed is physically compatible with a standard micro b cable at USB 2 speeds and with it's own micro usb super speed cable at USB 3 speeds. Considering he's talking about external hard drive the port is probably a Micro-B SuperSpeed which was and might still be common in external drives.
ugh, I hate that plug.  >.<
Yeah that one did exist, and it was terrible.
Yes, it's external hard drive. Like first image.
Okay then I'll stay with my default cable.
