I currently have the Corsair 4000x case and I like it quite a bit but I find that it is very big and I don't like how dark the side panel is. Ideally there would be a way for me to make the side panel less dark - so if anyone has any ideas on how to do that please say. But if not, I was wondering how bad the intake and airflow on the H510 is and if it as bad as some people say then what alternative would you choose. My budget would be around £60 - £110
https://linustechtips.com/topic/1402688-best-case-options/
iCUE 4000X/4000D/4000D Airflow Tempered Glass Panel, Clear (corsair.com)
But it seems to have a white frame...
Unfortunately above your budget, but very nice options:
If you want a solid front panel: Fractal Design Define 7 (Compact)
If you want a lot of airflow: Fractal Design Torrent or Meshify 2 (Compact)
If you want something cheap: Check out Phanteks P400a or P300a
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1402688-best-case-options/#findComment-15198334
