Hello, My pc suddenly shut down yesterday and didn't wanna run, after doing a full cleaning and unplugging>plugging the gpu power cable i noticed a red capasitor/resistor or diod (not sure) probably turned red from the heat while everything else on the card is cool at 35°, then few minutes later everything went back to normal except that spot is still hot (but not red as it was before), pc running normally,
I need some expert help on this problem, i'm gonna send a link to the pic woth the resistor/diod marked (i don't remember exactly which but i'm kinda sure 80% its the one marked to the right) Gpu is gigabyte r590
Link : https://ibb.co/DGzMf9B
https://linustechtips.com/topic/1402459-problem-with-gpu/
