hello
this is my spec:
ASUS TUF Gaming Z590-PLUS
Gskill TridentZ 2x8 16.0GB 3200MHz
Intel Core i7 Rocket-lake 11700
until now I didn't know XMP exist I always change my ram's mhz manually via bios now I heard from one of my friends that I should use XMP instead of manually because it sets proper voltage and latency.
with xmp voltage 1.35
without xmp  voltage 1.504
i also uploaded ss for better information (first one is xmp second is without xmp)
so which one is better? what should i do?? i dont know anything about what voltage or latency is good or bad so im happy if u educate me about it and guide me ty
https://linustechtips.com/topic/1402320-xmp-or-manual/
8 minutes ago, Albert F said:
usually there is no reason to go for higher voltage unless you need it. higher voltage is required usually for better stability, usually. I would say go for the lower voltage option just so your memory last more in the long run
im using my trident z rams for 6 years with high voltages by now, installed in my new rig and still working without problem...
what do you suggest?? xmp timings or manual timings with low voltage??
https://linustechtips.com/topic/1402320-xmp-or-manual/#findComment-15195992
if you have been fine with the high voltage setting until now go for it if it has any performance benefits. if it dosen't... well, it's a waste of power
https://linustechtips.com/topic/1402320-xmp-or-manual/#findComment-15196000
