also check if it's your charger your charger might be the problem
12 minutes ago, ItzMadMan said:
So my laptop battery is not charging, but, my laptop can turn on when its on battery power, but, it takes 12 HOURS to get 3%!
but because my laptop can turn on in battery power, it makes me confused.
is it a Dead Battery?
Sorry for bad grammer.
https://linustechtips.com/topic/1401915-dead-battery/#findComment-15193360
get HWInfo and look at the list of sensor data. Somewhere rather at the end of the list should be a battery section. There you can see your current capacity, its full charge capacity and how much it is (dis)charging with. IF the value for charging is really low (like 5 watts or so) I would consider checking your power brick
https://linustechtips.com/topic/1401915-dead-battery/#findComment-15193417
