1 hour ago, Ezra_Build_CO said:
Budget (including currency): 1000
Country: United States
Games, programs or workloads that it will be used for: Minecraft, Subnautica, Subnautica bz
Other details No extra peripherals, high-resolution, 60 fps if possible
I know that you technically requested AMD, but with all the new Alder Lake parts, you could do something like this pcpartpicker.com/list/wntnmk
it's a bit over budget, but it should perform noticeably better than any AMD system for the same price point.
