Need Help
Solved by MonkeyNutsUK,
12 minutes ago, Avocheeseado said:https://uk.pcpartpicker.com/list/KZP6nL
That CPU is a great choice. AM4 is at the end of it's life cycle so a new motherboard would be required to upgrade to the 6000 series AMD (assuming that's what it's called)
Mobo I have changed to a cheaper but still great one
RAM is also the same specs but cheaper
- I am assuming you already have the case and power supply? Because if so, you could potentially go for an even better CPU and mobo, although what I listed should be all you
I don't have a case or power supply yet and Thank you so much for your help I just. I just needed a bit of guidance thank you
