Motherboard Ethernet Not Working
tl;dr check other points of failure more closely
Okay, so I am NOT crazy. Or maybe from a reader's perspective I am, I'm not sure. The problem ended up being that the GFI that our switch is plugged in to keeps getting tripped, which is why it was cutting in and out. It finally went out for good. Our switch only has one tiny LED on it, and with the lights on, I didn't notice that it was turned off. I went back in there to check it again and forgot to turn the lights on, therefore I noticed that the little green glow was missing. Seems like an electrical problem instead of a PC problem! The time I tested my xbox's connection was when it was going in and out, so maybe I should have checked it again once it was out for good. Anyways, glad to find out my brand-new motherboard doesn't already have a fried NIC.
