hello guys I need some help. I just finished building my new pc, but every time I open my games, the games crashes or freezes. it seems like everything i download gets corrupted, installed and reinstalled steam, csgo, ark survival many times and everytime its says there is some corrupted files. i can start the game but after max a couple of minutes the games either crashes or freezes.
the specs are:
Phanteks Eclipse P400A RGB White
intel Core i5-11400 processor
CM Hyper H411R ARGB
Corsair vengence RGB PRO DDR4 3600MHz 16GB
ASUS ROG Strix B560-A
Corsair Force MP510 series NVMe PCIe M.2
ASUS GeForce RTX3060Ti TUF OC V2
Corsair TX750M, 750W PSU
Things i have tried:
tried countless drivers for my gpu, and made sure to use ddu to uninstall the ones that dont work.
tried checking windows updates.
tried using driver easy to update all my drivers to the newest.
tried scan my computer for corrupted files it found some but it said it fixed it, but it didnt.
tried checking if my microsoft account was corrupted
https://linustechtips.com/topic/1399323-please-help/
Just to rule out the easy stuff first, did you make sure to run DDU in safe mode, did you uninstall all graphics drivers including Intel (and AMD if you had an AMD card in there before), and do have your monitor plugged into your GPU and not your motherboard? This is almost certainly a GPU driver issue, and outside of reinstalling Windows, this is about as good as you can do.
https://linustechtips.com/topic/1399323-please-help/#findComment-15175885
yes i ran DDU in safe mode. i uninstalled only nvidia wich is what i use. and yes both my monitors is connected to the gpu with dvi cable. i have already reinstalled windows twice, i tried downloading windows 10 instead of windows 11, because someone said that could be the problem but i wasnt.
this is what my steam says:
https://linustechtips.com/topic/1399323-please-help/#findComment-15175893
