44 minutes ago, C2dan88 said:
Its crashed.
Windows install should not take longer than 30mins to go from running the install to seeing the desktop.
Force reboot it
Reinstall windows if it still hangs at the windows logo.
I tried rebooting it and it didn't work. I'm going to try another solution out. Thanks for the advice
https://linustechtips.com/topic/1398924-help-please/#findComment-15173616
