5600x Cooling issues?
Solved by Somerandomtechyboi,
2 minutes ago, MistahHaskins said:
Should I reseat the cooler though?
If you are already under 70c why even bother?
at this point id prob do a minor overclock to maybe ~4.8ghz for abit of extra performance if it doesnt mean shoving volts through the roof, cause under 80c usually means theres some performance potential, on ryzen i wouldnt really go above 1.35v just because diminishing returns though they are fine upto 1.45v
