Budget (including currency): $1300 CAD
Country: Canada
Games, programs or workloads that it will be used for: Minecraft, Far Cry, COD, CS:GO, and I would like to be able to record/edit videos
Other details:
-I already have a monitor available to me
-This would be my first build, so I would probably want a prebuilt, but I wouldn't mind building my own
-The goal is to be able to record and edit decent gameplay at 1080p
-Ideally would like 60+ FPS for most titles (Although it might not be possible with my budget)
https://linustechtips.com/topic/1398228-looking-for-advice-for-first-pc/
Country: Canada
Other details:
Do you happen to have a GPU?
If not, you will likely need to spend half your budget on one to get something decent.
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
Country: Canada
Other details:
This seems to be a half decent pre-built.
The i7 9700 and 1660 SUPER should be able to handle most titles at 1080p with 60+ frames.
I'll let you know if I find something better within your budget.
Country: Canada
Other details:
What is the refresh rate of the monitor? If it’s only 60hz more won’t help much.  A few of the titles you mentioned are supposed to benefit a lot by 100+hz frame rates.  If your monitor won’t do it, the amount of help those higher frame  rates give is limited. Lately the hard part is a GPU.  The best iGPs can get pretty close to the lower end sorts of 1030 (apparently all 1030s are not created equal.  Has to do with memory type mostly iirc) so for a new machine that is something of a minimum.  Such things can often run things at 1080p low. So if that is all you have use for, Xe or Vega11 IGPs may be enough.  If not one needs a decent GPU and they have been hard to get for reasonable prices lately.  Standard move is to first get ahold of a good deal on a video card, and then build the system around that.
Thanks!
No I do not, but I am willing to spend some on a decent GPU.
I believe it is 144hz so it should be good. Thanks for the advice on the GPU, i'm thinking potentially a 1660 SUPER or something like that (not sure if there are better alternates for the value), which atm is around $640 (on PCPartPicker)
13 minutes ago, gamer854 said:
Thanks!
That use to be a sub $300 card (plus it’s an old design) to give you an idea of the price hikes involved
Yeah, GPU prices are insane right now.
I did find a PC on newegg for about $50 over my budget, but I can just wait a little longer and be able to get that one. (Link: https://www.newegg.ca/abs-computer-technologies-ali416/p/N82E16883102994?Item=N82E16883102994)
That PC is a solid option. It depends on whether you think the extra $100+ tax is worth it for the GPU upgrade and slight cpu downgrade.
The 2060 will be approx 20-25% faster than the 1660 SUPER.
The 9700 and 10400 should essentially perform the same in game, with the 9700 pulling out slightly ahead due to its higher clock speeds.
The 9700 should also outperform the 10400 in processing tasks outside of games, due to increased clocks and 2 additional cores.
Likely resulting in approx a 10-15% increase over the 10400, according to benchmarks.
Okay, thanks! I did create this build on PCPartPicker that looks pretty solid (it's out of budget, but again I can save). Could I get your opinion on it? Thanks you again! https://pcpartpicker.com/list/6RX2K3
My recommendation...
PCPartPicker Part List
CPU: Intel Core i5-11400 2.6 GHz 6-Core Processor  ($239.98 @ Newegg Canada)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($71.48 @ Amazon Canada)
Storage: ADATA XPG GAMMIX S11 Pro 512 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Best Buy Canada)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($49.99 @ Amazon Canada)
Power Supply: BitFenix Formula Gold 650 W 80+ Gold Certified ATX Power Supply  ($59.88 @ Canada Computers)
Custom: ASUS Dual Radeon RX 6600 8GB GDDR6 PCI Express 4.0 Video Card DUAL-RX6600-8G and ASUS ROG STRIX B560-A GAMING WIFI LGA 1200 Intel B560 SATA 6Gb/s ATX Intel Motherboard Combo ($808.99)
Total: $1290.31
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $1290.31
Thank You!
Total: $1290.31
If you wouldn't mind me asking, do you know where I would purchase the GPU/Motherboard? TY!
Its available at Newegg Canada.
Link - https://www.newegg.ca/Product/ComboDealDetails?ItemList=Combo.4434555
SSD TIER LIST
CPU - Ryzen 7 3700X
There’s a whole list of specifically Canadian hardware retailers on PCpartPicker when you choose Canada as location afaik it works for more or less every country option though I understand the Indian one is a bit complex because there is so much mom&pop there.
