Just put it in the PC and connect the cables if it is SATA. Then start up Windows normally before you right click Start menu and choose Disk Management to open it in right click menu.
Locate your drive to initialize and create partition on it.
https://linustechtips.com/topic/1397171-installing-hard-drive/#findComment-15162686
2 minutes ago, Tan3l6 said:
Can you be more specific?
As adding a (secondary) drive in your computer does not compel to install OS on it.
i have a seagate sshd 1tb and it has windows in it but when i boot my pc they sometimes w=switch from the 1st hhd to the 2nd hhd but i want the first hhd to be the main one to boot
https://linustechtips.com/topic/1397171-installing-hard-drive/#findComment-15162694
i already did it but how can i remove the os in it while its the secondary hhd or i just format
https://linustechtips.com/topic/1397171-installing-hard-drive/#findComment-15162697
