Budget (including currency): "Yes"
Country: New Zealand
Games, programs or workloads that it will be used for: Twitch, YouTube, Netflix, Games like LoL, Myth of Empires, Rimworld, Minecraft, Halo Infinite etc
Current PC:
  • R7 3700x
  • Cooler Master Hyper 212 (Default Fan)
  • G.Skill Ripjaws V Series 32 GB 3200mhz CL16
  • EVGA GeForce RTX 3080 10 GB XC3 ULTRA GAMING
  • Corsair RM (2019) 750 W 80+ Gold PSU
  • Corsair 220T Mid Tower Case (3 front fans 1 back fan - ones that came with the case)
Hi all,
I built this PC last year at the end of Spring. We had a really hot summer and my fans were kicking it at really high speeds and so I couldn't really play any "beefy" games with it also being a huge heat output (turning my already toaster of a room into a smeltery) but didn't have much in terms of money to get more cooling sorted. During 2021 it was rather cool for us and so I completely forgot about it until now. 3 days of 25ºC (77ºFreedomUnits) of hot weather outside turns my small room into a smeltery yet again, and yet again don't have the money to sort out cooling BUT I am looking at sorting this issue out.
Does anyone have any recommendations on a Cooling Plan/Setup that I can use so that I don't turn my room into a smeltery during 2022's summer - Temps can range from 20ºC to 30+ºC
Edit: I should mention I am not at all looking into water cooling - thats a mess I want to tackle later on in my life
Edited by Birphon
System Specs:
CPU: Ryzen 7 3700X
Cooler: Cooler Master Hyper 212
Graphics: 3080 XC3 ULTRA GAMING
RAM: GSkill Ripjaw Series V 32GB 3200mhz - CL16
Case: Corsair 220T
https://linustechtips.com/topic/1397113-cooling-upgrades/
Doors and windows open.
Unless you stop using as much power, the heat output will remain the same
https://linustechtips.com/topic/1397113-cooling-upgrades/#findComment-15162445
Unless you stop using as much power, the best output will remain the same
Windows are open
Door is closed for Privacy reasons (and so its not as noisy for when I am talking to people)
System Specs:
CPU: Ryzen 7 3700X
Case: Corsair 220T
https://linustechtips.com/topic/1397113-cooling-upgrades/#findComment-15162447
21 minutes ago, Birphon said:
Windows are open
Move the pc out of the room then. There’s not really a solution outside of this aside from using less power
https://linustechtips.com/topic/1397113-cooling-upgrades/#findComment-15162459
