Help setting up blade server
Go to solution Solved by Electronics Wizardy,
You probably don't want to use this. It seems to be about 20 years old now.
 Is going to be very old now, and basically can't run a modern os.
Its also power hungry and loud.
Id really just get a newer system, and not use this system.
Hi folks. need some help setting up a blade server it is a Compaq Bl10e blade. it will be used for file shareing solid works files since me and some friends  do 3d printing and cnc. and then it would have been easier to have a common server we have our documents on. but I do not know how I set it up. have searched around a bit but have not found anything that can help. does anyone have any experience setting up such a server?
And sorry for the bad english its my second language
THX
https://linustechtips.com/topic/1395706-help-setting-up-blade-server/
