10 minutes ago, terabase said:
RTX 3080 ti
or
RTX 3090
If you ask me in their MSRP, 3090. 300$ for basically extra everything and getting the effective titan of the generation is better than the 3080Ti ever could.
With the world right now? Between the 2 you can get.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1395353-help/#findComment-15151073
yea but in todays prices, whats worth lol
https://linustechtips.com/topic/1395353-help/#findComment-15151120
Again, what you can get. Theyre both neck in neck in scalping price so whichever the 2 you can get non sclaped or least scalped is your winner.
https://linustechtips.com/topic/1395353-help/#findComment-15151231
2 minutes ago, terabase said:
but like which ones will give me better performance, cause i can get both
Well then in that case, 3090.
https://linustechtips.com/topic/1395353-help/#findComment-15151317
