Quiet Case + PSU?
Go to solution Solved by quan289,
The Cooler Master V550S is also a good option, and it is $69.99 after MIR. http://www.newegg.com/Product/Product.aspx?Item=N82E16817171092
Hey guys, what's sup? I just have a quick question, I wanna go with a quiet case and PSU, (I already have my eyes on the R4). Though I don't know any good quiet PSU.... can you help me out and if you could find a cheaper case than the R4 and still as quiet that'll be nice. Thanks!
Edit: Budget is around the 200 mark that max I'll go.
The time you enjoy wasting, is not wasted time.
https://linustechtips.com/topic/139418-quiet-case-psu/
R4 with Corsair RM series PSU
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859023
To provide you with a recommendation for a PSU, it would be helpful to know what the PSU will be powering. Also your budget.
I plan on going a 6300 with a 750 ti maybe a 770 later down the road mate.
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859062
A RM550 or RM650 will do you just fine, depending on budget
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859072
Was thinking of it, but 100 for a 600 watt? No thanks.
well you wanted a recommendation for a silent PSU and i gave it too you
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859077
Well, I would recommend the XFX XTR 550w. It's a Seasonic G unit internally but offer full modularity and a higher quality FDB fan that is more quiet. It also a better build power supply than the popular RM series.
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859080
I know, my bad for sounding like a jerk. I should of included a budget.
well what @quan289 said is a good PSU too,
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859114
I think I might go with that one, Plus free shipping? Sounds prefect... thanks!
https://linustechtips.com/topic/139418-quiet-case-psu/#findComment-1859136
