Hello fellow users off Linustechtips,
I am for the first time build my self a gaming desktop, Iv'e used a laptop for around 6 years now and felt it was the right time for an upgrade.
I do not have loads of knowledge on the various components, but iv'e research some. Finally Iv'e figured out a build but I have a few questions regarding my new build.
Here is the build, I know it's a danish site, but you should be able too understand the various parts ^^
https://www.komplett.dk/k/shoplist.aspx?mode=receive&si=1374475&su=C006EED8-13A4-4B34-B991-C74FCAF9A0A7
Some questions:
Do I have enough cooling for the system?
Will the mid tower be enough, specially for future 2x SLI 780Ti?
Anything you see as a problem in the build (Everything fits right)?
And of course if it's possible for you to find a case WITH a window that is as simple as the 450D please show me some links, as I havnt been able too find any ;) (Not that I do not like 450D)
Best regards Shamatix.
https://linustechtips.com/topic/139348-first-gaming-build/
Thanks alot Paralectic, my biggest concern is the case, if it's big enough for cabel management :- )
You need to quote a post or tag a member or else they won't get a notification you replied to them.
It should be plenty--that's what case reviews are for.
Regarding the build:
No point getting an i7 over an i5 or such an expensive cpu cooler for gaming.
The 780 Ti is a bad value. I'd suggest getting a 780 or 290 instead,
Why such an expensive motherboard?
No point getting high frequency ram for gaming especially when it has such high cas latency.
Why a high frequency TN panel instead of a better looking IPS?
Caviar blacks are not worth the extra money for anything but the warranty over the quite cheaper and only slightly slower barracuda.
https://linustechtips.com/topic/139348-first-gaming-build/#findComment-1873999
