What PSU do you have? That could very well be the issue but it doesn't have to be.The HD7450 requires significantly less power.
Have you already tried using DDU? You should always do this when swapping GPU's, and chances are that since both are Nvidia it's just a corrupted driver.
https://linustechtips.com/topic/1393370-graphics-card-issue/#findComment-15137625
This sounds like a driver or windows issue to me too.
I would recommend DDUing and continuing from there
https://linustechtips.com/topic/1393370-graphics-card-issue/#findComment-15137646
i have a corsair cx750m, i have just tried a DDU its still restart after 1 secound without there comes a picture on the screen
https://linustechtips.com/topic/1393370-graphics-card-issue/#findComment-15137753
43 minutes ago, fubu500 said:
about 6/7 years
  It's probably just showing it's age then. High quality PSU's usually last about 10 years, and a budget PSU like this a little bit less. I think it's time to buy a new one. I'd recommend something that's 550w or higher with good quality. Some good options are Corsair RMx, Be Quiet Straight Power 11, Superflower Leadex III, MSI AGF
https://linustechtips.com/topic/1393370-graphics-card-issue/#findComment-15137831
