Need help with PC fan
By
Oyerk
in Troubleshooting
in Troubleshooting
Solved by HanZie82,
Just now, Xbox Professional YT said:At this point, would I need to replace the fan, or would I just need to link the broken wire together?
If the fan works, and the speed of it doesnt bother you. Its fine.
Like i said its only to report back rotation speed back to the computer.
Most likely it will run at 100% if it doenst know.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
