I am taking my old aio from my alien ware aruora and I want to put it into my NZXT H510 case, but my predicament is I cannot fit the cooler on the top or front of my case, therefore my only potion is to put it on the back end of the case by the io shield( the AIO only has one fan and a small radiator. I was wondering if this is alright to do or if it will sustain.
https://linustechtips.com/topic/1392516-aio-problem/
29 minutes ago, hasan12345677 said:
NZXT H510 case
That back fan slot is where you usually see a 120mm radiator in that case.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1392516-aio-problem/#findComment-15131439
The case works better with negative pressure anywas. So rear mounted aio is fine.
https://linustechtips.com/topic/1392516-aio-problem/#findComment-15131979
