Country: England
Games, programs or workloads that it will be used for: bit of everything
Other details: I just got a new gaming PC but the front panel didn't have its cables in it and I know you don't need them but I'd like them still please help also why does it have so many pins
https://linustechtips.com/topic/1392198-front-panel-help/
The pins for that will be on the case.
What case, and what motherboard are those?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1392198-front-panel-help/#findComment-15128967
-> Moved to CPUs, Motherboards, and Memory
Look at the pinout of the connector in the motherboard's manual, and the case wires should be labeled, match the 2.
F@H
GPD Win 2
https://linustechtips.com/topic/1392198-front-panel-help/#findComment-15129058
